For the second time, I’ve shot gelcoat for a mold, only to have it lift as it cures, from a concave area of the plug. Laid down approx 30 mils (wet), mixed around 2%. It “B” staged in an hour or so, then I followed up with tooling gel (MEKP @ 1%) a couple layers of veil and a layer of 3/4 ounce CSM to “stabilize” everything. At 10P last night all seemed well. Checked it again this morning (10 hours later) and, the last 12" or so (near the edge in that concave area), had lifted/bridged ever so slightly! Went ahead and pulled the piece off. Other that waviness in the area that pulled, it’s not too bad.
What I’m wondering is, best intentions aside, if I shot myself in the foot by using the WOLO on the pattern? I clayed the edges, and the problem SEEMS to be where the gelcoat is “pulling” between the clay and some higher spots on the pattern, and the WOLO is SO effective that there’s not enough surface tension to hold stuff in place as the resin cures?
So, what are my options? Cut the MEKP in half to kill the heat and slow it down? How far back can you safely cut back w/ tooling gel (US Composites/black)?I did a temp check during all this, and I appeared to be getting around 80-83 degrees in the lay-up, and a 1 - 1.5 ounce leftover sample in a cup was clocking around 180 degrees.
Anything?
Save for for a little alligatoring (my fault), I’m quite pleased.
