I’m working on a project car of a friend of mine where several parts will be cf (hood, right-left door, rear door), right now I’m in the process of the mold making. until now everything was great but today while i was gelcoating (polyester) the back side of the hood i had some shrinkage (alligator skin), i’m pretty sure that this happen due to the different gelcoats i used. let me explain, in the first layer i brushed a red, low viscosity gelcoat (i’m guessing it was for spray gun) for the majority of the surface but because i didn’t have enough quantity i also used an orange, thicker viscosity. then 3 hours later i brushed the second layer of gelcoat, this time i used only orange, during the whole process i had the mold outside into direct sunlight and 20C temperature, but a little later i saw that in the places that i overlapped the red gelcoat it started shrinking :(. i had no knowledge of the difference in the gelcoats until i used them and unfortunately i never thought to check them before i start the process because it bought them as the same kind of materials.
now my question is: can i laminate over the gelcoat as it is (i don’t mind if the mold has surface issues because my thought is to sand-bondo-primer-clearcoat it afterward) or then only way is to remove it and start over again? if i have to remove it what’s the proper way to do it without messing with the upper half mold which is already finished?
i tweaked the close view pic so it would be more obvious the problem
