Hi,
First of all thank you to everyone who has replied to my previous requests for help, using what I have learned so far I have had a go at infusing and apart from the obvious in the attached picture, 90% of the part has the exact finish I was hoping for.
Yesterday I applied a coat of polyester gelcoat to a crude mould I machined quickly in work. I applied this as best to my ability and let it cure for around 4 hours before I laid in a 300g fibreglass mat, then a 2mm soric mat, the a final 300g fibreglass mat. The mould surface is perfect and not at fault, that would be me of course. Infusion took around 8-10 minutes for the record, the soric flows quite quickly however I may try some combination mat soon to compare the speeds.
The part is around 600mm x 300mm and is only a test piece.
The gelcoat if anything seemed like it wasnt as tacky as I would have expected, however when I started to lay the first layer in this did stick nicely to the surface. The part was infused with polyester resin and left to cure for around 20 hours before I removed the bag and pulled it from the surface I cast it against.
I am wondering if anyone can advise what I did wrong please? I am guessing that the gelcoat thickness was a problem here (too thick or thin) or hadn’t cured long enough before I infused. 4 hours did seem a little too quick however I had to get some progress made by today and it is only a test part. The pattern seems to be ‘sucked up’ at this location if that makes any sense to anyone?
If anyone has any ideas I would really appreciate any comments. I am due to test another piece later today and will be sure to either wait longer or try any suggestions others may have.
Thanks again for everyone’s support.
