After sealing (FMS Sealer) and waxing with TR-102 regular mold release wax (10 coats, 1hr between coats) I sprayed the PE tooling gel coat today. Why didn’t the gel coat lay down and flow out to a smooth coat??? What did I do wrong? Here are the steps that I followed (hopefully you guys can tell me what I need to do differently to improve the results).
[FONT=Calibri]1. [/FONT]Ambient temp this AM was 94 degrees (Arizona)
[FONT=Calibri]2. [/FONT]Installed the included FN-6 nozzle in my new G-100 dump gun - spray volume adjusted nearly all the way closed
[FONT=Calibri]3. [/FONT]Adjusted the air pressure (filtered) to 70-75psi continuous at the gun (this is the max I can get when running through my current regulator)
[FONT=Calibri]4. [/FONT]Mixed my orange tooling gel coat with duratec high gloss additive (4:1 approx)
[FONT=Calibri]5. [/FONT]Catalyzed with MEPK at 2%
[FONT=Calibri]6. [/FONT]Sprayed via steady sweeping passes approx 18-24 inches away from the surface of my plug (spray pattern at an approx 70 80 degree angle to the plug - nearly vertical)
[FONT=Calibri]7. [/FONT]Sprayed one med heavy coat (I noticed a few fish eyes in areas that the spray pattern was light – as in where I didn’t fully overlap the last pass) – I hit the fish eye areas again and they filled in
[FONT=Calibri]8. [/FONT]Waited approx 5 min and sprayed another med heavy coat
[FONT=Calibri]9. [/FONT]Total thickness was approx 30 mils (on the low flat areas – the gator looking ridges would have been thicker)
[FONT=Calibri]10. [/FONT]Waited approx 30-45 min and applied two (2) layers of light weight veil (CSM) and VE resin
[FONT=Calibri]11. [/FONT]Waited until that kicked off (waited until the stuff cooled to near ambient following the exotherm – max BTW was approx 135 degrees)
[FONT=Calibri]12. [/FONT]Applied the first two layers of 1.5oz CSM and [COLOR=black]Iso-phthalic PE tooling resin (404 tooling resin from US Composites) – Catalyized at 1% - the laminate reached a peak exotherm of 142-145 degrees[/COLOR]
NOTES:
I noticed the spray pattern with the G100 was only 3” wide or so at 18-24" from the plug.
I called US Composites and the rep that I spoke to said I should have thinned the gel coat at 10-15% with styrene (had some too, just didn’t think of using it). He also said I should have waited 15 min before applying the 2nd coat and then a couple of hours before applying the veil
I’m hoping the molds will be salvageable (I really hope I don’t have to start over but….)
Should I continue bulking up the mold with 1.5oz CSM and hope the gelcoat against the surface of the plug is smooth or do you think the severe wrinkly look in the pics is going to ruin the mold?
(pics below - the 3rd pic is after the two layers of veil had been applied - looks dry but its not)
Any advice will be much appreciated!
James
Phoenix, AZ
http://i1095.photobucket.com/albums/i477/jbocek/Glasair%20project/IMAG1039.jpg
http://i1095.photobucket.com/albums/i477/jbocek/Glasair%20project/IMAG1034.jpg
http://i1095.photobucket.com/albums/i477/jbocek/Glasair%20project/IMAG1042.jpg
) Its annoying that this happened and to be quite honest, im not sure why. To me, addition of acetone or styrene surely only decreases the viscosity of the gelcoat while spraying to make it easier to spray, leaving a thinner coat, etc. Sounds like you know what you’re doing spraying, so would adding styrene have made a huge difference? (Edit…looks like herman beat me to it!)
