A few weeks ago we purchased some orange tooling gel coat from Florida Fiberglass and we’ve been having some problems with it.
We made a mold of some flat parts and that went well. The mold was made with three layers of this orange tooling gelcoat and seven layers 1.5 oz matting. The matting was saturated with Hydrex 100lv resin from Express Composites. The HDT on the resin is 240f or so. The HDT we found out today on the gel coat was 122f. Does that seem very poor for a tooling gel coat? It’s a PE gel coat by the way…
Anyways… Today we left the mold under the heat lamps too long after infusing the part and when we came back the digital thermometer said that the mold was 171f. I knew right away that, that could be very bad. Sure enough, the mold was warped in several places. It’s ok because the parts are literal just flat panels, and we are making more molds as well to increase production. My fear isn’t if the gel coat is good enough to make molds to make simple door sills. My fear is making molds of parts that need t be cured at a higher temperature.
Can anybody suggest any other kinds of tooling gelcoat? Maybe a vinyl ester gelcoat? What about epoxy? If we use an epoxy gel coat will it have to be post cured?
Thanks, John.
