I’ve tried twice with the same result. I’m trying to build a small center console which has 3 vertical surfaces and 1 horizontal, kind of like an open box missing 1 side. My plug is nice and straight but after I pull it from the mold, the vertical surfaces are wavy in some spots, usually near the bottom by the flange. They are low spots in the mold, sometimes up to 1/8" deep.
I’m brushing the gelcoat on since it’s only about 12"x12"x2". I put down 2 or 3 layers about 4 hrs apart. It’s hard to get uniform thickness with a foam brush, but it’s about 20-25 mil in most places, some might be a little more like 30. Any ideas?
The horizontal surface comes out nice, save for a tiny bit of 'gatoring, which actually looks more like a small spider web and it’s so small (<1") that I can fix it. The smaller vertical surface is not as afflicted, but still gets some wavyness. Could it be to too much MEKP for the conditions? It was a bit hot at 85F and I still used 2%. Gel too thick in that spot, or too thin, causing a weird reaction? Maybe shrinkage? I might have waited a little too long (8hrs) to put 'glass on it.
Any help would be much appreciated.
i thought it was about time i posted something
