I am new to the composites world and have attempted to read as much as possible. I have made it to about page 100 thus far, so thank you all for the wealth of knowledge.
My question which I have not found an answer to, even reading product sheets is; What are the physical properties of a gel coat or even molecular properties of a gel coat that would explain why it is recomended and commonly used for the surface layer of molds?
Similarly what would be the difference between something labeled gel coat versus tooling gel coat? Same question with an epoxy top coat and regular epoxy resin?
-Sean
