hi everyone,
i’m planing a project and would like to ask a few questions.
- how do you get a perfectly smooth gel coat on both sides of your form
- whats the best way to get a hard gell coat with NO pinholes to prevent mold growth?
- any suggestions for this project…
project: i am going to build a chamber about 6’x4’x9 inches. the chamber will have a slight curve to it and no corners, all the edges will be rounded. one of the large sides of the chamer will be a detachable panel. i would like the inside of the chamber to have a smooth gelcoat and be mold proof. i also want the outside of the chamber to be smooth, but this is not the critical side.
i’ll fabricate the chamber and the door as two different pieces. so far it seems that i need to make a two part female mold for the chamber because a plug or male mold will get trapped inside the casting ( the panel will not take up the whole side).
by using a female mold, the ouside of my form will have a gel coat on it. and i’ll have to brush a resin/gelcoat on the inside, but this will leave streaks won’t it?
thanks for any tips you have,
max
