I need to make a composite fuel tank support tray for a street car. I believe there are also two steel straps that wrap around the fuel tank and underneath this tray support part.
Full fuel tank weighs 175lbs. I’m not making a new fuel tank, just the tray. So all you engineering types if you could help me determine how thick the fiberglass needs to be for this application? The bottom tank dimensions are approximately 38" wide x 21" and it is not a flat bottom there is one angle of about 15% and the tank tray support has curved outer edges that hug the bottom of the tank and extend up about 2" around the perimeter of the tank.
I will probably be using just one layer of carbon fiber twill 12oz and the rest of the cloth will be fiberglass. I’ll be using epoxy resin.
So, if you guys could help me out with how thick this new part should be - that would be awesome
