I am looking at a 1971 Porsche 911 as a long term restoration project.
This one has a sunroof that for a number of reasons, I want to get rid of.
The biggest being the removal of some 60 lbs from the highest point of the car. (the sunroof panel is very heavy)
The best solution I could think of was to remove the sunroof and hardware, cut the hole somewhat larger (75% of the roof area) and form a Carbon Fiber plug with a flange to fit from underneath. After bonding, a few layers of high build primer and then its off to paint.
I have 2 concerns with this concept.
- Is there a possibility of galvanic corrosion with the steel body. Will the resin block the electron flow or would a coat of self etching primer do the same. If primer is good, does it then become the weak point of the bond?
Do I need a layer of fiber glass between the CF and steel?
Or will the paint seal it well enough to prevent this problem.
I am planing to keep this car for decades, so it is important to get to right.
- Thermal expansion.
Am I going to have issues with paint cracking as a result of the different coefficients?
Thanks in advance to all the experts out there.
Rob
