I am trying to clean up my shop space and want to get rid of a composites curing oven I built. This is a photo from halfway through assembly: http://i.imgur.com/vZll56i.jpg
The insulation is foil faced rockwool and the foil tape in the joints has a 600F adhesive. The floor pan is 20 gauge mild steel. There is currently no heating element in the oven but I can include a PID ramp/soak temp controller and an AC fan designed to be mounted with the motor outside the oven. The oven is extremely heavy but has castors to make it easy to move around. I don’t have a truck or a way to transport it so if someone wants it, you will need a large vehicle that can move it. I am located in Durham NC.
