Hey everyone, I am hoping that some of the more experienced infusion people on here can help me with a problem I am encountering.
I will describe our problem and then our-set (as much as I can legally explain)
Our problem is as follows: We are in a manufacturing environment and over the past 2-3 months we have been experiencing a pesky problem. We are using the VARTM process to infuse parts. After the bags are ready the operators leak check the parts for 1 hour with a required 0 leakage (the spec says 1"hg in 5min but since the problem has come up we are trying to get in much longer leak checks). The operators then infuse the part and close off the resin feed line when the infusion is complete. This is where the problem is coming in, while the part is waiting for cure it will randomly spring a leak. Sometimes after 5min, sometimes 1 hour or 2 hours, who knows! If the operators notice the leak right away then can (most times) use infusion bagging tape to stop the leak. If it goes unnoticed then our part is ruined.
I have tried many things to help solve this problem. I was convinced that the WL7400 bags we were using were becoming too brittle towards the lower end of our in-spec humidity requirements. So we switched bags but the same results are persisting.
Our infusion set-up is as follows: 2 part resin system degassed for 15minutes
pee ply extends 2" beyond part and 4" where the infusion pack will sit
greeflow mesh cut 1" inside of layup
infusion pad (fitted with a t-fitting and hose to resin feed)
spiral tubing wrapped in peel ply (to make sure the spirals do not cause bag leaks) which extend the lenght of the part and 1/3 down the sides of the parts as well.
Thanks in advance for any help that I may receive
