probably is the same, like I mentioned its the most common that I’ve seen.
there are no UV stabilizers added to the VE that I know of, but because it is a more a poly based resin it should be more resistant that Epoxy. I’ve never seen any of my parts have UV damage with VE but I did have one come back with a chalky look to it (actually one of a pair). One of my suppliers was convinced it was from water damage. I still think the clear coat that I used wasn’t the best for that application and came off. :rolleyes:
“”“Vinyl Ester resin is very similar to polyester for working characteristics. Vinyl ester is a slightly better adhesive and is significantly less brittle than polyester. Cured UV resistance is neglectibly slightly less than polyester. Cost wise, it is about 30% more expensive. If you are making fiberglass repairs, go for vinyl, not polyester.”""
—cant remember the site where this is from sorry
