I rebuild my snowmachine every year and modify it to make it lighter, faster, stronger ect. I was going to build a full 4130 chromoly tube chassis this summer but have decided I want to build a foam core carbon fiber chassis instead. A few companies already build carbon fiber products but, but no one has done a foam core yet.
My main objectives are lightweight, and unparalleled strength. I plan on using 1/2" Divinycell foam for the entire structure. This includes the tunnel, bulkhead, subframe, gas tank, seat frame, ect. I plan on vacuum bagging everything in stages and bonding it together.
We have a local supplier(I’m in Alaska) for Divinycell which is why it’s main choice. From what I’ve read it has high strength/stiffness, resistance to fatigue, and high impact strength. Snowmobile go through an incredible amount of abuse. Jumping, rolling down mountains, sharp impacts from trees, ect. I just have a few questions.
Since I’m using a foam core, how many layers of cloth would be recommended? Would one on each side be sufficient?
My exhaust runs under the tunnel and I assume gets hotter than 180* which I’ve read is the breakdown point for Divinycell. Would extra layers of carbon protect against this or would I need an aluminum heat plate?
Will the foam be stiff enough to bolt engine mounts too? I’ll also have a chaincase that will need to be mounted.
Here’s a picture of my sled
Here are a couple more I got off the internet that are not foam core
