I sometimes use cardboard tubes cut in half and lay glass over that, or rigid foam cut into strips, anything to give added dimensional change and thus more rigidity.
that video of the guy using epoxy slurry is good though, how much resin would that take…? I’ve used epoxy with aluminim filler and those work great. If you’re gonna go down that route and you’re only making a few dozen parts, you can also use plastic faced plaster molds which are much much much cheaper than pouring all that resin. You wouldn’t even know it was plaster if you build it right, until you pick it up. It’s good for small molds.
