flow media weight
I’m considering using divinymat or standard core with flow media on an infusion. Approx. how much weight does flow media add to a lamination. There must be high resin content.
Flow media weight?
I always have peel ply then the flow media on top, so it comes off with the peel ply. SO for me flow media is 0 weight.
Unless you’re talking about inter laminate flow media?
The foams will absorb resin and thus add weight. Really what you should do is some test panels so you have a quantitative understanding of how the core will react. I’ve done panels with foam cores, PVC, and found them to be very heavy. SOric seems to be much better and absorbs less resin. Not sure what thickness you’re in need of but, definitely get some samples and see what they do in an infusion.
