Hello all,
I’m new to the forum. I have made a few composite parts in the past ranging from wet lay to prepreg (school project). I have just setup a workshop and have a new project!
More on point:
I have prepped my plug and constructed a wide flange around it. I now want to flare the plug to flange with clay. I plan to roll up some long cylinders of clay, push it into the groove between plug and flange, then gently scrape or form the clay with a plastic straight edge. My concern is the scraping of the plastic edge on my prepped plug. Will I locally remove wax at the contact point from dragging the plastic across the plug?
Is that clear?
