So here is the deal
I’m prepping a plug and it will have to be a multi piece mold (3 pc).
I’m not sure what to use as flanging for the part lines, up till now I have been using some thin Al sheeting, but cutting this stuff is a bit of a pain since I have to use some tin snips/side cutters and getting a very nice smooth cut is not possible(partly due to the serrated blades of the snips and the fact that it’s hard to cut curvature into the sheets)
Also I am not sure what to use to seal the gap between where the flange and the surface of the plug will meet to form the part line.
Ontop of all this I am not sure what to use for a release agent. I don’t want to hassle with PVA for this job. I’m considering using either a semi perm or waxing the enitre thing. I’m a bit hesitant in using the semi perm or the wax as a release (each alone as the release agent) since I have never done that before. I’m worried about sticking the part or damaging the plug (which is actually a mint motorcycle tank).
Suggestions and tips would be great! Thanks.
