Being a total newbie at this “fibreglass” thing I was always under the impression that whenever you make a mould you would always have to make some flanges on it (this was from after reading tutorials on this site and other forums/sites).
But then after searching a bit more, I see that people make moulds like the one pictured below for example without any flanges
So what my question is, when do you need to make flanges and when do you dont? Is flanges only required when working with cf for vacuum bagging and not fibreglassing or something?
Also another question I have is, what is the advantage of using multi-layers of fibreglass against one thick layer? For example I wanted to make a part that was equivalent to a thickness of 600csm. Now I can use 4 x 150csm layers or 2 x 300csm layers, what would be the adv/dis of both?
Im assuming the one with more thin layers would be more “hard”? while the one of less thick layers will be more flexible? Also how would this apply when using chopped strand and cloth?
Sorry for all the questions, Im just planning to make my first bumper mould and would like to make it in one go rather than wasting time and material and having to do it twice. For a bumper mould how “thick” would one recommend anyways? and for the actual item? I plan to add some flex additives in if possible.
