What method do most people use to machine the flange off the casting? A Dremel? A Router? A Saw? In my application, my parts must join flatly where the flange is removed. Imagine a hatch cover, and that’s essentially the part.
When I use a dremel, my cuts are inconsistent.
A router requires a jig, and my first design also made inconsistent, (damaging), cuts.
( Both are SLOW!!! )
I’m considering using a table saw in a two step process to: 1) Cut the flanges down perpendicular to the part’s base near the finished part to make them even and manageable, and 2) a jig which cuts them parallel to the part’s base at the proper height (H). (Pardon my sloppy scribble!)
What do you think?
