First I just wanted to say great forum! Everyone seems really knowledgeable and helpful. That being the case…
I’ve seen some different ideas about making flanges and was just wondering what everyone around here does. If you have a relatively flat part, or at least a one-sided part the flanging is pretty easy as you can hot glue them on from the backside. What about when you have a part that you need to make a two part mold from? What do you use and how do you attach the flanges to the surface of the part? I’ve tried hot glue (after waxing the part) but it’s a pain to get off and usually damages the part in doing so. Oil based clay doesn’t seem to want to hold onto the waxed surface that well so I don’t really trust it to hold the flanges where I need them. On the part I’m doing now I’ve been trying to make a paper template of the flange I need and then trace that onto metal “For Sale” signs. This works ok, but sometimes the paper templates tend to fit better than the metal ones as they have a little more give if you’re not paying attention when fitting the paper ones. Plus I haven’t really figured out a good way to attach the flanges together yet if they are larger than one sign (and they always seem to be. :rolleyes:) I just pretty much leave a little overlap and glue them together with that and clay up any gap left on the front. It works ok, but I’m sure there are better ways and materials. Any suggestions? Is there an easy way to make a template? On a curved surface I just pretty much have to guess and draw it as close as I can and then start trimming until I get it close. Then I just use clay to fill in the gaps. It works ok, but takes awhile sometimes. Thanks in advance!
) I actually will probably try a combination of all of your suggestions. Thanks again!
