I am making a plug of a wing. It is 60" long and 12" wide. I am currently sanding, and sanding, and sanding, and sanding to get it perfect. The trailing edge wasn’t straight, so I was using my 15" sanding block to get it even. For whatever reason, perhaps the combination of Bondo fumes and Budweiser, when I got to the end I wasn’t seeing straight. I basically sliced back the end 5 inches a small amount. At the very end, it is about 3/8" cut back, and it tapers in a straight line inward 5 inches where it is correct.
I was about to mix up some microbubbles and try to somehow form the correct shape. It would involve putting the putty in, letting it set up for 24 hours, and sanding the crap out of it hoping I don’t mess up and have to start over. I was about to get the epoxy out when I smashed my elbow on my block of clay. That gave me another idea.
Since this is a plug, maybe I could install the parting boards and then use the clay to make the shape. The worry is that it would not be perfect, and I’d have to fix the mold itself if it were way off. But it’s only a sliver of defect.
What would you guys do if you were me? Any advice would be greatly appreciated. Thanks!
I was trying to use layman terms.
