Hi,
I’ve just demoulded my first carbon fiber vacuum bagged piece.
It has 3 layers of 200gsm 2x2 twill CF and the resin is Sicomin SR1500.
I wet layed up the first layer and let it partially cure, then I layed 2 more layers and vacuum bagged with a vacuum pressure between 0.5 and 0.6 bar.
When i demoulded, there were some milky patches on the surface as well as small to large pinholes and small areas where there was no resin coating ( although I believe the fabric is wetted)
These are pictures of the results:
The milky patch seems to be resin with a lot of micro bubbles.
-How can this be avoided?
-Is this structurally dangerous or just a cosmetic issue?
-If I sand the piece and then do a thin coat of epoxy can I “hide” these a bit?
