I just release a OOA prepreg I tested a surface layer on the glass.
The surface doesnt have typicall resin voids, it is rather resin rich but has some kind of imperfections which I belive where caused by entrapped air while laying prepreg on glass. When i lay prepreg on glass I check out the under side and there was many air pocket closed by prepreg , I tried to push them out by finger but that didnt help.
So i left it like it was (with this air pockets) connected vacuum , compressed it for 30 minutes - but still nothing change , so I left the part under vacuum , turn off the pump and put the part to oven.
The part was cured in oven for like 10 hours at max 90 degree, after demoulding it was stiff and strong but surface look like this :
