So, I popped out my first plug the other day. I had sprayed the plug with Fiberglast orange tooling on a beautiful 75 degree day with an ES cup gun. It looked pretty good and even. I had spent a long time on the plug sanding and polishing to get a great finish. Plug release prep was done with a few coats of Frekote 700NC. Here’s how thing’s went…
The Frekote comes with no instructions and the only video I could find was about a water based release, but I followed the same wiping instructions. the video showed how tape was unable to stick to the prepped surface, but tape was sticking very well to my prepped plug. The frekote also left residue that I could see, as if you had wiped your car down with a wet paper towel and then left it to dry like that.
Note to self: Try to get at least a 5CFM compressor if you’re going to use a cup gun.
The plug was a flat piece but gel coat still got underneath it when spraying. Chalk it up to a learning process. Next time I’ll use some clay. is that the easiest fix?
After sanding down where the gel coat had gone under the plug so it wasn’t locked in anymore. I attempted to get it out. I’m not sure the Frekote did anything or if that was even the right thing to use. I was saved by the fact that the plug was a resin covered solid piece of wood, so I could bend the mold itself to pop out the plug. I didn’t over-reinforce the mold just for this very reason.
The gloss had not transferred to the mold. It was smooth, but a dull finish. I could also see the residue marks from the Frekote left on the plug. By the way, at what grit would you start with to go after the gel coat finish at this point?
Anyway, any comments or feedback about anything above is welcomed. Thanks!
