Im infusing a large panel using fiberglass with a Soric XF core.
This is my first time infusing using a core and I had a question about how much resin to use.
When I normally infuse a part without a core, I weigh my cloth out and mix up the same amount of resin by weight. This usually results in having more resin then I need, so I then adjust the amount of resin that I use down as I make more pieces and can accurately see how much resin my part uses.
Now my question is regarding core material. Should I treat the weight of the core material the same as standard cloth? If I weight out all my cloth and core material and mix up an equivalent amount of resin, would that be a good starting point?
Im just worried that I will either mix up way too much resin or too little for the infusion. Any help is appreciated!
