so i tried my first infusion the other day after trying to do some flat carbon sheets with conventional wet layup , but always getting some sort of imperfection in the piece
if you havnt tried infusion on a part where it is possible , i HIGHLY recommend it if you need a great cosmetic looking part
my sheet 1000x350 of 200gsm plain weave carbon and a layer of 80ish gsm glass came out PERFECT ! even though i had a leak
and this is the point of the thread … you have read how important a leak test is , IT IS !!
i knew i had a really small leak, but i couldnt find it , so when i clamped up i lost vacuum … the thing is when i did a test it held vacuum for a good 15-20 mins , but after infusing maybe 30-60seconds later and the bag started showing signs of slack
i guess i was just fortunate that my piece came out great ( i layed another bag over and bagged again) but now i know , if there is the slightest leak , it turns into a nightmare !
