Hi guys tomorrow i will be attempting my first ever infusion, i seem to have all the materials but i dont have the T connector which feeds the resin into the spiral, any ideas on how i can feed the resin into the spiral.
thanks
thanks
Assuming you have a resin feed hose penetrating the bag and are sealing the bagging material with a sealant tape product , wrap the spiral line around the end of the hose a few inches .Rolling some release fabric around the spiral tubing will prevent the bagging material from wanting to suck into the spiral under high vacuum . Depending on how strong your pump is the bagging material can cut itself on the exposed spiral edges .
Good luck on your first infusion . You will always remember your first . Have fun !
My first was better than my last.
