Hi
I am attempting vacuum infusion for the first time and have I few questions. I have read numerous guides on the subject but there are still a few things I am not sure about.
I have an estimate of the surface area of the part and I know which material and how many layers I am using. How do I calculate how much resin I need form this information?
How important are flow media, I have been reading a guide about this subject on fiberglast.com. Do I need to put a layer of flow media between each layer of carbon fibre? Am I correct in saying this is not necessary if using fibreglass?
Also does anybody now a good supplier of flow media in the UK. I only need relatively small amounts so do not want to buy in bulk.
Is the diameter of the vacuum and resin tubes important? What kind of diameter should I choose? What kind of plastic should the pipe be made from? Will the pipes be reusable?
What strength of vacuum pump do I need? What pressure needs to be achieved?
How tightly should the vacuum bag fit over the mould before I turn the vacuum pump on?
Thank you very much for your help, it is greatly appreciated as I have never attempted vacuum bagging or vacuum infusion before.
If you need anymore details to answer these questions please let me know.
All flat pieces are really easy…just need a bit extra bag to cover around the tubes, and you are set.
