hi all… ok so i ve been reading many posts regarding the above and it appears for cosmetic carbon people recomend placing a clear gel coat down first…my question is…planning on using poly infusion resin but i currently use surboard resin for overcoating normal vac bagging bits am i able to use this as a gel coat or better to use actual poly gel coat?
or once last question is it wise to use a little bit of spray adesive on on some carbon fibre if its an awkward mold to lay up ? if i wasnt using gelcoat
many thanks and great website…very helpful
