Im doing a few parts by vacbagging in carbon all epoxy layup. Im going to start with the west system 207 hardener on the first layer then a laminating resin therafter. Im wanting to do some parts clear (which i was going to spray duratec clear) once out of the mold.
Im also wanting to do some parts in other colours, what can i use that i spray into the mold first then lay up? Is ther an epoxy gelcoat? Or can i use poly gel coat?. And is there a way of spraying in a primer first as well so i can produce primed parts straight out of the mold??
Thanks for any help guys
