Hello everyone,
My name is Ryan and i’m very new to the composite game. My Brother and I are refurbishing an Old Jetski and i came up with the Idea of doing FO-Carbon Fiber on the handle bar post. The Post is made of plastic but we used WB 400 epoxy resin and covered it with a sheet of Carbon. The question that i have is this.
AS expected, since we did not use a mold or vacuum of any kind we have airbubbles in at the very surface of the resin. we also have some thin areas that have the whole snake skin look going for them. What i was thinking, and let me know if this is ok, or if there is a better way. I would litely spot sand all the surface bubbles. Then scuff up the peice, and apply another coat of the WB 400. let that dry, litel wet sand it, and finish it with an automotive clear coat. To cut off the extra fabric, we are going to apply extra WB 400 to the areas to cut making sure it is nice and stiff. Then we will rough cut out the shape, Sand it, re Epoxy the edges then run a thin black pin stripe around the edge to hid it before apply the clear coat.
This is what it looked like before the carbon, We used black tinted fiberglass to get a round shape.
Then after the Carbon it looks like this.
Thanks for you time.
