I have been producing composite rifle stocks for about a year, I have made many mistakes and found many methods that have yielded a better and more repeatable part.
Current process: Stock shells are laid up as a single piece using a two part rigid mold. Materials are E glass, S glass, carbon fiber, and Kevlar, all using epoxy resin. One half of the mold is laid up with the material below the mold mating surface, the second half is laid up with overlap. The overlapped side gets a bladder inserted, mold is clamped together and the bladder is inflated.
Current molds: Molds are made using tooling gelcoat and multiple layers of fiberglass reinforcement using polyester tooling resin, it is then backed with a wood frame and 16 lb rigid pour foam. The current molds do not hold up well over extended mold cycles before they start to chip, which require repair. I have also had difficulty ensuring the molds do no flex during layup. The fiberglass seems to hold up fairly well to the current pressure the bladders are inflated to, but maybe not so well if I attempt pressures well above 40 psi.
The finished product does not require a great deal of attention, I feel the weakest link are the molds. I was considering a few options to improve the molds cycle life, and here is where I need input.
Rigid molds: When choosing a method and material to produce rigid molds, here are the options I am aware of;
epoxy mold, fiberglass reinforcement. What would I choose instead of polyester tooling gelcoat? Can the standard epoxy be used for a primary surface coat?
aluminum molds. Issue is the product has some detailed grip areas (similar to a swim step texture) that would be extremely difficult to machine due to it’s random patterns. Also very costly.
Semi rigid molds, using a thin silicone or urethane mold surface backed with a rigid mold “deck”, aluminum or fiberglass reinforcement.
I keep coming back to the semi rigid mold idea for a few reasons; First, the mold would seal at the surfaces and could allow vacuum/resin channels to be molded in. Second, due to the softer contact surface, minor mechanical locks wold be far less of a concern. Third, mold life, I am assuming the softer material will be a lot less likely to chip, but may be very difficult or impossible to repair.
