Fiberglassing Vs. Laquor
ok ive gotta clear this up
i have no idea which to do… my uncle is telling me to use laquor… he said he use to make sub boxes and sell them and he would use laquor and he would get the exact same finish that he would if he were to use fiberglass…
which should i use?
so far ive taken my center console,did resin,fiberglassmat,and bondo, i gotta primer it and then putty then start to put the color on (using a black laquor spray bottle for the black color which my uncle said i shoudl use for that finish)
so for the center in gunna do it like that…
now for anything else i want do to… such as door panels, dash trim, glove box… should i use laquor? or fiberglass? whats the difference between the 2… which is better? which do u think i should use?
thanks guys
(ps. im going for the finish u see in car shows, hard and u can basically see uriself in it)
This is kind of confusing since laquer and fiberglass are two different things. Fiberglass is used to make structural parts while laquer is just a finish. I’m not really sure what you’re getting at.
