Hey guys,
I was wondering if you could give me more information on using very light woven fiberglass cloth (0.5 - 0.7 oz) as a way to protect against pinholes on a part.
In my application, I’m doing a wet layup in a bag. I’m actually ‘self prepregging’ the material on a flat surface (metered amount of resin per square area of cloth, and distributing it as evenly as possible) and then placing the part in a mold. I’m using breather to wick away excess resin (along with P3 perf ply, if someone could give me a line on where to get anything other than this damn airtech stuff I’d really appreciate it. it seems like that’s all anyone sells in the US), and because of it I’m still getting quite a few pinholes that take a serious amount of spraying and sanding to get rid of.
So, my question is, if I insert a layer of this fiberglass into the part, on the surface layer (between the mold and carbon), will it solve the problem? If it’s 0.5-0.7 oz, is it really “crystal clear”? These parts have a cosmetic application as well. I tried a test run with 3.7 oz cloth and it was terrible, you could definitely see it.
Can you guys break down the application and procedure for me in detail? All of the other threads where it’s mentioned just throw it out there and aren’t elaborated upon
Edit: just for extra detail. I’m using Gurit Sp115 ER and the carbon is 3 to 6 layers of 5.7oz
