i need some advice on what to do about the mold i made…chuck it and start over or fix it.
it has a few air pockets…it looks way easier on the internet…then when you have epoxy all over your gloves an itch on your nose and the fiberglass is sticking to everything i thought to my self, hmmmm this isnt as easy as it looks. i did figure it out about 3/4 of the way thru. so the back side looks better than the front…:mad:
i think i should have started with a thinner fiberglass for the first layer. its the money layer. i think thinner would have conformed better.
anyways, i have a few air pockets. can they be fixed? if so…how???
im not sure what happened here…
im thinking, what if i filled a syringe with mixed epoxy and inject the blisters? then when they set up, sand them smooth. do i need to take a trip to the ghetto and buy a syringe off a heroin junkie (a new one of course)? my luck i would probly go to jail LOL.
So that mold is just Epoxy and glass? You should look into a epoxy surface coat. This is epoxys version of gel coat basiclly. I think that could help your surface finish alot on the next mold. I would use this mold to practice filling in the small holes incase their is any problems with them on future molds. Try to get this mold to working condition but don’t be mad if it doesn’t work. Use it as practice so your next one goes that much easier and looks that much better. I’ve thrown plenty of molds away in my time. :mad2: I think it’s either two things that are causing those bubbles. Ethier it’s because you’r just learning mold making or that woven glass just doesn’t want to conform.
I think just like rotor… Push through this one an learn all you can.
