bridging and bubble clusters can be caused by poor vacuum bagging technique. It takes a lot of practice, making sure to pleat the vacuum bag ( youtube search " carbon fiber vacuum infusion Civic hood" also that the bag is air tight…even a pinhole leak can cause air bubbles in/on the laminated part. There are leak detectors you can buy, but most people here I believe just use their ear to listen for leaks… put your ear close to the bag.
Also if you are wet lay up - vacuum bagging… make sure to use either peel ply or perforated release ply and on top of that compltely cover the laminate with a layer of breather. No breather means that area not covered will likely not get sufficient vacuum pressure… also make sure your vacuum line connection at the bag has a lot of breather cloth. You need a steady path flow for air to reach every sq. inch of the laminate.
Are you wet lay up and bagging, or just wet lay up no bagging, or vacuum infusing?
I know with vacuum infusion it is especially critical you have no vacuum leaks. even a tiny pinhole leak can leave the part riddled with air bubbles.
To help solve bridging… use just use 2hg of vacuum or so to massage the laminate stack down tight to the mold surface… use a paddle tool in corners and along edges. Once you have it all massaged down, apply full vacuum. If you have time before the resin kicks… release full vacuum and massage the stack down once again… then re-apply full vacuum.
But on rolled edges you will need some type of mold shaped tool to lay under the vacuum bag and over the release ply/peel ply. This is to evenly apply pressure and force the stack to that curved rolled edge.
