Hi there
I am working on testing by FEA a carbon boat hull we made over here in West Sussex
I use for the FEA the following values of Mechanical properties of the generic Carbon Prepreg composite laminate
Elastic Modulus 90000 MPa
Poisson Ratio 0.27
Tensile Yield Strength 915 MPa
Ultimate Tensile Strength 862 MPa
Ultimate Compressive Strength 848 MPa
Your feedback will be highly appreciated in regards accurate mechanical properties values for carbon prepreg laminate .
Thank you
