So i started to do an overlay project for the interior of my car. I have a post of my initial piece in the showcase section. Since I am new I was hoping to get some tips for a particular part that i need to wrap.
Little info: I am using simlar 249a resin with red/black carbon kevlar. i am using a hand layup process no bagging.
Its not the easiest material to cut so here is a picture of the part that I want to wrap as you can see the top three ari vents are recessed on the bottom of the vent about 1/4". I want to lay the fabric in there to make it look complete instead of an overlay.
So if there are any tricks that would help.
Here are my thoughts
1: Try and cut small holes before I lay the fabric- trying very hard not to have pulls in fabric. I have serrated shears that cut well but they are big.
2: lay fabric down on first resin layer let dry and then try and cut a hole carefully put down some resin in the airvent hole and then lay down fabric-basically two step inital step
3: dont lay it back there and do everything normal and just make sure the section is black to avoid any major eye sore.
Let me know if there is somthing i am missing. Any help would be greatly appreciated
Here is the part:
