I made a fiberglass seat cowl for my sport motorcycle. It has a latch on one end to keep it closed ( think of a truck bed tanuo cover made of F/G). The other end has a hinge bolted to it via some wood inserts I resined/glassed onto the bottom side of the part (seat cowl). The hinge has a spring that is kinda strong because it’s made to hold up a seat that weighs 3lbs. I was worried a little about the spring being too much pressure on the inserts… sure enough it is pulling one insert off on the side with the spring. All of this flexing and pulling has distorted the shape of the part a little and it now looks ugly. I used polyester resin and Bondo brand fiberglass cloth ( .008" thick)- 3 layers of cloth and a lot of resin rolled into the cloth, and on both sides after it dried i applied more resin. I waited two months before i mounted the part so it had plenty of time to dry.
Any ideas on how to make the next seat cowl so it doesn’t have this same failure occur again? I would like to use a spring to keep the cowl open on the hinge end when needed… but i can go to a lighter weight spring… just not a lot lighter weight.
