So I have a large 3 piece mold and I want to modify the shape. I was thinking of using an expanding foam that I could pour into the mold and when cured I could get to work shaping as i like.
I have bought a test sample of Smooth-on Foam It3 which is an expanding polyurethane foam and I tried it on a smaller mold made of similar materials as the larger one. The molds have semiperm 700nc as a release agent. Once the foam had cured I pulled it form the mold(successful release)but the mold surface of the foam was softer then the side exposed to the air, and it started to crackle and seemed to collapse with only a gentle touch. I contacted smooth on to see if they could shed some light on the situation but they didn’t know why that had happened. Also I think this foam was not dense enough for what I would have needed… Plus it was ~$40 for the small units!!
Anyone have any suggestions of a good quality higher density foam they have used that can be machined or sanded and is strong enough to stand up to handling and then finishing with bondo type fillers, paint and clear? Would you also know if the foam could be released with 700nc semiperm?
Thanks.
