I seem to be having this problem with patchy gel coat adhesion. It seems like the gel coat and carbon are not fully bonding (see pic). Any thoughts? :?:
What I usually do is spray down a layer of clear gel (50/50 mix of clear gel and Duratec high gloss additive help to make more transparent) and let it cure. This way the mold is set when I need to use it. Then I infuse using VER and let cure overnight under vacuum. I have seen this on a couple parts, but this did not happen with Evan and I used epoxy. I am wondering if it has something to due with the VER on the cured gel coat whereas the epoxy has better adhesion properties. I could switch to epoxy but I am trying to keep the costs down.
The nose of the engine cover had the same problem.
