First off, hello all! I found this forum when I decided to make my own composite motorcycle fuel tank. I found an interesting epoxy resin to try, being “green”, with several benefits I thought Id try it out and do several samples and tests. I made up several strips with the Ecopoxy and Im going to leave it in the ethanol fuel over time to check for any degradation.
Then I get on here and find out epoxy is great for strength and adhesion on the composite fibres but not so good for ethanol resistance. I do a little more digging and find vinylester is more resistant to the fuel but not so good for strength and adhesion to the fibres.
I was planning on coating the inside of the tank with a sealant such as POR15 or Caswells tank coating anyway, but could I make the tank with the epoxy resin for the first 6-7 layers and then use the vinylester resin for the remaining 3-4 layers? Would they bond properly? Is there a different resin I can use?
Ive got more questions but Ill try not to use up all my question alowance in one go!
Ray
