Thanks Hojo,
yeah i found with this epoxy 30 to 45 minutes works well between epoxy tooling gel coats. I did 3 layers of tooling gel coat, i wanted it thick enough for repairs and sanding if needed later on. This yellow is kick a**. Very bright, i love it.
I’ll start laminating in about 10 minutes or less, since i just applied the final tooling gel coat. I’ll do three layers of glass cloth 0,45,90 degrees lay up. I’ll bag it too for a few hours since this resin sets up kinda fast. This is fun:D
20_RC51… i made my own epoxy tooling gel coat. 4ounces of epoxy, heeping tablespoons of calcium carbonate dust, and 3% yellow epoxy dye. That did a seat cowl size mold with a 3" flange all around it. Mix the calcium carbonate to get a really thick pudding viscocity, after the epoxy part A and B are mixed for two minutes add the c/c. Then add the dye and stir it in real good. Should be rock hard when fully cured.
