While doing an overlay tonight I was wet sanding and noticed the touch up areas started turning this milky blue color. I’m assuming this is from the moisture???
I had thought that the resin had cured but I guess I was mistaken. I’m pretty sure the weather has slowed my cure times way down as even I type this its below freezing.
So my questions:
Will this go away or am I stuck sanding this back out?
What do you guys that live in colder climates do to deal with tempatures?
