Epoxy Resin suggestions for Vacuun infusion
Does anyone have any room temp Epoxy resin systems they have used and would recommend for vacuum infusion? Laminates will include S2 Glass, Kevlar/Carbon Hybrid, Kevlar, & Carbon. I need something with a low viscosity and a reasonable potlife. Clear resin as opposed to something tinted or pigmented. Also, a post cure is not an option at this time because of the part size (50 sq ft +).
Bob
Bob,
How about Sys 3 SB-112 or Jeffco 1703? SB-112 has a mix viscosity of about 400-500 and Jeffco is about 300+ You can heat up the resin a little bit to thin it out. I have the SB-112 but I don’t have the Jeffco. That was just something that someone recommended.
Evan
I could be wrong. That was just off the top of my head
