Looking for a substitute to Duratec primer for epoxy projects.
Found that House of Kolor makes 2 products that sound like they are what im looking for.
KWIKURE EPOXY PRIMER (KP21)
KP21 is a 2.1 VOC hi-solids catalyzed Epoxy Primer that meets all current air quality regulations. It is designed to be the first primer applied to bare steel, aluminum, fiberglass, magnesium and galvanized surfaces. It’s strong adhesion, hi-build, excellent durability, and corrosion resistance make it the logical choice for the base of a long lasting paint job.
CHROMATE FREE EPOXY PRIMER (KP2CF)
KP2CF is designed to work over properly prepared aluminum, magnesium, fiberglass, galvanized steel, OEM finishes, and some woods and plastics. It’s strong adhesion, fast build, and ease of sanding (wet or dry), make it a logical choice for the base of a lasting paint job. It may also be applied to repair areas for fast filling touchups.
Dont understand the difference between the two ?
edit * Chromate is a rust inhibiting primer. Used primarily on aircraft. It’s a olive green to light green in color.
But anyway - since HOK is pricey, kept looking & found a hotrod site that had lots of guys saying good things about this 2part epoxy primer product.
http://www.southernpolyurethanes.com/Product%20lines.htm
Sticks like glue & sands easy - I think this would work well for finishing urethane foam plugs & top coats ?
http://www.hotrodders.com/forum/epoxy-primer-question-46638.html
