Epoxy + pigmet VS epoxy gelcoat
Hi guys,
I have to repair a few windsurfing boards, they’re made of epoxy, all of them are white.
I only have polyester based gelcoat, and I don’t want to use it on these boards.
So, should I order some epoxy gelcoat (not available locally), or should I just add some white pigment to the epoxy?
The advantage that I see of using pigment are:
[ul]
[li]Different colours
[/li][li]If there’s a scratch, the colour behind the “gelcoat” would be the same, so it won’t look that bad
[/li][/ul]
What do you guys think?
BTW, the pigment that I was thinking of using would be:
http://www.fibermax.eu/shop/white-pigment-p-215.html
that’s 18.54 € for 1 kg
That would be cheaper than epoxy gelcoat.
Well. since you are not using a mold to make these…you don’t need a gel or surface coating.
All the surfboard types are foam shaped, wrap for reinforcements and then resin coat and sand / polished…
But I do need the repairs to look nice, they should blend with the rest of the board. That’s why I want the repairs to look as white as the rest of the board.
I’m finally ordering some SP pigments to be mixed with epoxy.
I would agree… just tint your epoxy white yourself. make sure the epoxy you are tinting is clear… not amber. 3% tint ratio.
If you use white, let us see the mixed epoxy or final results :slight_smile: i’ve never used white pigment myself. I use mostly yellow, black, red.
I’ll be using my clearest epoxy and will post some results.
I’m also getting some black tinting for other boards, will post the results.
Cheers
