I’ve been searching for a great epoxy with some certain properties.
It will be used for infusion so it needs to be 700cps or higher.
It needs to be clear, not amber or dark color.
I’d like it to be hard, at least Shore D 75, preferably higher.
The shear strength to be 3,500psi or more.
Also non-blushing (cycloaliphatic) hardener.
Room temp curing.
The resin i currently use is a tad thick for infusions @ 600cps 70F. Also it’s a bit too flexible, like it’s not hard enough. perhaps i should be weighing out each component before mixing, i do it by volume instead. The Shore D is 70-75. The shear strength is 2500 psi. Modulus of elasticity is 5.7x 10 to the sixth power.
