So I just visited Michigan Fiberglass works (Chris is an awesome and very knowledgeable guy!) - picked up a ton of supplies (GREAT prices BTW! ;)) Couple cool projects they have going on there - both infusion. One is a kiteboard, the other a 9’ boat. Tomorrow or Thursday he will be infusing the kiteboard, then in a week or two the boat. Going to attend both sessions for sure as I have never infused nor seen it done.
In any event, Chris was very insistent on using Vinyl Ester resin instead of Epoxy for my jetski hull build (remember, this is a watercraft and will get a lot of abuse). He stated that the physical properties of it are much stronger then that of epoxy which can brittle over time.
And also instead of using an Epoxy paste/mixture as an adhesive for motor mounts, hull inserts, etc., use a product like Plexus.
Just wondering what others opinions are on this? Until now I had it in my head epoxy was the ONLY way to go.
If layup method matters, right now he has me talked into doing infusion (I am going to take my molds and materials down there when it is time) and he is going to help me out.
-Andrew
